Engine Runs Rough, Stalls, Hesitates on Acceleration
chevcamls1
hi i have a 96 ocean pro 200 and every time i go on the water motor runs perfect but after a while like half hour the motor stars running rough and hesitates on acceleration i give it more gas it gets worse i also notice that every time i hit the gas hard gauge beeps and check engine light come on. last weekend on my way back i removed the engine cowl and the only way i got it to run a little better was by moving the carburator lever not moving the timer base linkage
fireman57
When was the last time the carbs were cleaned? Also, are you sure that it is not overheating? Is the beeping short beeps, long beeps? You can search the beeps and it will tell you what to look for.
chevcamls1
Short beeps temperature is fine 115 degree i dont think is the carb cause when i push the carbs linkage it runs perfect i'm thinking it has something to do with the base timing
Chris1956
Honorary Supreme Mariner
2-cycle motor? Check Engine alarm is high vacuum in the fuel line, indicating motor cannot pull enough fuel to safely run. Not sure why this is only a problem in warm motor.
It is pretty simple to check the timing, so it makes sense to rule that out.
