First, thanks for taking the time to review my concern.
I have a 1991 Baja Islander 225. I got the boat with a bad engine (2 pistons damaged). I rebuilt the engine last spring and it has never run right. Here is the boat information:
Year, Make & Model: 1991 Baja Islander 225
Mercruiser
Outdrive: Alpha 1 Serial# OB887782
Prop: Currently has a 19p (have tried 17 & 21p)
Engine: GM V-8 Small Block 350, 5.7L
Cylinders are 0.030 over
9.5:1 aftermarket pistons (Summit)
Cylinder Heads from GM 305 (raises compression slightly. Est 10:1)
Camshaft 465/488 282/292 (from Summit)
Factory Rockers
Edlebrock Performer Air Gap Aluminum Intake Manifold
Edlebrock Performer Marine Carburetor, I believe its a 600 (new)
Spark Plugs: AC Delco MR43T
Ignition: MSD Ignition box/module
MSD Distributor
MSD Ignition Wires (new)
What it's doing:
At the end of last season, I found that it had low compression on all but 1 cylinder. Removed the heads and found that all of the valve stems were at different heights on the top. Also noticed the #1 and #2 (one on each head) intake valves had been hot and started to suck the valve in (con-caved). Therefore, I replaced the heads this season with a set from a 305 chevy. The valves were lapped, seals replaced and springs replaced with some slightly used Summit racing springs (don't know specifics but was told designed for the cam I have). Did not correct the lack of power. Tried a few different props thinking the 21p was possibly too much. It did run a lot better with a 17p but then was revving too high.
Yesterday, I set timing at 0* and it wouldn't start. Set it to 8*, still no start. Set it to 12* and, while pumping the gas, it might start but run very poorly and won't idle for more than 20 seconds. Advanced timing to approximately 25*, based on timing light adjuster dial cuz I can't see the mark on the flywheel otherwise (Indicator is at 2 o'clock position and mark is somewhere around the 12 o'clock position) it starts, runs and idles well. Under load and WOT, lacking power and pinging (indicating too far advanced). Turn back timing slightly, pinging not as bad, gains power. Turn back more (guessing about 20*) it starts running rough at idle and stalls when put into gear. Can't handle any load. Turn back any more, starts popping/backfiring and wont idle at all (indications of too far retarded).
At first, the timing mark was erratic when checking with the timing light. In the process of elimination, I replaced the MSD Module, distributor, spark plugs and wires. Corrected the erratic timing mark but did not change the timing/running concerns. We also thought the timing mark was off on the balancer thinking the rubber spun. However, I checked for TDC, confirmed timing mark dead on 0*.
I have been running regular fuel and it has been suggested to run premium based on the raised compression. However, we do not believe that this is the cause of the timing concern. It may help with the pinging but will not correct the timing issue. I could be wrong tho.
The fuel is good and clean. The carb was replaced before I got the boat but was never really used after installed. I did go through the carb just to make sure there were no restrictions; it was spotless. The fuel pressure has not been checked but does not appear to be a problem. A quick test using an known good electric pump was attempted and this did not make any difference.
After running the boat on the lake, I idled back down a short channel (about 5-min) and pulled it out of the water. When I pulled the spark plugs, the color was pretty good, a slightly darker golden color. No signs of a lean or rich condition. No excessive smoke from exhaust.
The only thing I can think is that the cam gear is off a tooth. However, most people have told me that it likely wouldn't start or run at all if that was the case. The reason I believe this is due to the amount of advance needed to run the engine. Does 20-30* advanced = 1-tooth off??? My brother and I put the engine together last March. He is a long-time GM technician, very experienced with engines. I am not a top notch tech but I do have quite a bit of experience in this field.
I am planning on working on it this evening. Going to do a quick compression test to see where that's at. I am considering putting it in the water and doing a vacuum test to see what kind of readings I'm getting off the manifold. The main plan for tonight was to pull the timing cover to confirm the cam and crank gears are aligned properly as this is the only thing I can come up with at this point.
I would love to hear some other opinions as to what steps I should take next. I am at a loss.
Thank you for taking the time to review my concern.
Mercruiser
Factory Rockers
MSD Distributor
What it's doing:
