i am almost ready to fire up a boat in which i have not seen run. the firing order on the old air filter cover says reverse firing order. it is a 454 motor. i need to buy a starter. does it have to be reverse spinning? can you tell from the prop if indeed it is reverse order? it has linkage in the outdrive that you can change the position of, to chane rotation. please help this is a little confusing.here is the prop.http://s176.photobucket.com/albums/w192/kfcz400/?action=view¤t=091.jpg
