Engine revs up
oceanrunner0000
I have a 1995 Johnson Venon. I rebuilt the carbs and installed. I adjusted the idling screw about 5 and half out. It idle rough. I sprayed carb cleaner in each carb while running. I noticed on two of the carbs the motor slightly rev up. On the other four carb, it tried to die-out. I have the engine in a flush bag and the RPM about 800. What could be wrong with those two carbs revving up the motor?
