FreeBeeTony
- May 15, 2002
- 3,991
Re: Engine replacement question
Almost sounds easier to change over to a SBC...............
OK...........
Just seemd like your "locked-in" to a 302...............not many available upgrades there.
Do I need a special intake? I read that some intake have provisions for water passages and what not. What do I get?
-barry
I have the four barrel 215hp version. My engine comes stock with a holley 450cfm 4 barrel carb.
-barry
It is a 21' caravelle cuddy cruiser
-barry
I did this last year. I bought a 1977 Sea ray with a 233 hp ford (351)
the motor mounts are the same it bolted up perfectly no issues at I thought. Then I went to hook up the exhaust didn't realize the Y pipe was wider under no circumstance could I get the new exhaust hose to hook up. As I didn't want to take engine out for the fifth time I had a forklift to take it out but I had to remove exhast manifolds and dizzy to install. I had the 233 y pipe that had three allan screws to remove I was able to get in and remove while was still in boat Thanks Don S for that info. The boat I have is a 1973 jolly roger yes that is the manufacturer. This boat is 17 feet long and is able to go 63 on the gps with his engine. Oh by the way I left the 888 outdrive in after the installation. This is a great combo no problems at all other than rust in gas tank that clogs line which is another issue altogether. Hope you have no problems with 302 but if you need on I have one sitting in the shed.
