Re: Engine Quits
I still think it is fuel delivery problem.<br />The timing will rarely move out of adjustment on it's own,unless an adjuster backs out, or linkage breaks.<br />The symptoms you describe are almost allways due to fuel starvation. Check the tank's pickup tube for an obstruction, and make sure the vent screw actually allows the tank to vent.<br />Check the carb.<br /><br />The fuel pump on your motor operates off of compression,so check the compression. The check valves in the fuel pump can leak-by, and only supply enough fuel for idling sometimes. So if the compression test checks good, rebuild the fuel pump. The kits are only about 15 dollars, and the pump is not complicated....The only cautions are, make sure the check valves go back in the right way (they can be put in backwards on this pump), and clean. You may also find the diaphram half-eaten by time and alcohol additives in modern fuels. Also, use locktite or other threadlocker on the fuel pump screws, as engine vibration has been known to back these screws out,and if you try to overtighten them,they will strip out.<br />Good luck.
