Engine Question for 1988 Bayliner Capri
Gene F R
I just bought a 1988 Bayliner Capri 2.3 Liter SOHC, with an OMC Cobra motor, model# 985267. When I try to start the boat, it will turn over but it won't start. The guy I bought it from said that the points needed replacing. Could that be the problem or did I get duped??
If anyone has any suggestions as to what the problem could be please let me know.
Thanks,
Gene
dubs283
Re: Engine Question for 1988 Bayliner Capri
head up to the adults only sticky and have a look at the points ignition troubleshooting link
tobymac32
im having some wiring issues i think what is this adults only sticky cause my coil get red hot in about 10 min of just the key being turned on
divinginn
Try unhooking the coil and turning the key on and see if the wires are heating up,it could be the coil shorting. If not the coil work your way back from there,a good multimeter will help.
tobymac32
put a ballast resistor inline and problem solved thanks for the help
