engine problems - PLEASE help!
jeffhvaughn
98 Force 120hp
- motor cranks ok - a little hard at times, but will crank
- will idle ok (a little rough), but stays running
- when given throttle, will get to about 2100 RPM and that is it. Will not go anymore. Won't even get to plane.
- When not in water (with earmuffs), engine will rev and reach max rpms (5300). Even if it is put into gear on the trailer (with earmuffs), it will reach max rpms.
Found the top carb air flow guard cracked and gummy grease just inside of top carb. Removed and cleaned with carb cleaner per instructions on can. Took out on water and same symptons.
When on the water and running, I can remove cover and manually engage throttle at engine (by using lever) and get TONS of white smoke. And it almost sounds like it is about to choke out but will engage and rev really high.
Did compression check and all 4 apear to be within 120-135 range.
Do I need a carb overhaul? How much does this cost if taken to the shop? If done myself? could it be as simple as the choke being stuck? How do I check this?
eurolarva
Re: engine problems - PLEASE help!
Carb job is easy to do yourself. Locally here they charge around $100 to rebuild a carb.
Pull your spark plugs and look at the tips. Do they have even wear and burn on all plugs? Up until the part about removing the cowl and getting full power my guess would have been one cylinder not firing. Now maybe it is fuel related. Also rebuild the fuel pump. For 9 bucks it is easy and gets rid of one more potential problem.
