I finished rebuilding the power head on my 2000 mercury 225 EFI after a melted #2 piston, started the motor and it sounded good, I shut the motor off after a few seconds and decided to take the injectors out and test them with a 9 volt battery, all were functioning properly. I reinstalled the injectors and started the motor again, it fired but went to full speed imediatelly it will not slow to idle, not linkages were moved. Where is my problem?
