SouthAfrica75
Thread starter- Joined
- Feb 24, 2008
- 9
Hope others on here can give suggestions to my issue.
Yamaha 150 (carb). on a 21ft CC
Start the day..... Boat will start after a couple of cranks and run great a idle speed for the 10 minute ride out. I then run the boat around 25-30 mph for approx 20-30 mins with no issues.
I then stop for about an hour or so for lunch etc.....
When I get back on the water for my return trip is when my problems start. The engine starts up with no problem and runs at slow idle speed with no problems.... However when I head out and bring the boat up to 20 - 25 is starts to "bogg down" as though starving for fuel... no matter how much I throttle up, there is no power and the boat almost stalls.....
Plugs and fuel / water seperator changes in May this year.....
Could it be a carb problem or a water in the fuel problem ????
Should I change the fuel / water seperator and see if that helps
Thanks
Thanks
