Engine Oil
misslynnie
1998 - Mercruiser 350 - V8 - 5.7L I/O
Having a problem with engine oil and lower part of motor overheating. I have cleaned both risers (not bad) and manifolds. Port manifold replaced, starboard cleaned (very good flow). Oil pressure maintains 40-50 psi. Motor and oil both cool when rpm's are lowered from 3000 to 1000 rpm's. Temperature was measured with I/F gun. Checked water flow at all hoses leading to and from thermostat housing (OK). Thermostat was replaced along with water pump before overheating.
What should be checked and or tested at this point.
Miss Lynnie II
mkast
Re: Engine Oil
Just curious, what temperature reading are you getting?
Pulse8
Re: Engine Oil
check if your Y exhaust isn't blocked by a old pair of exhaust flappers which could be broken and fallen into the Y exhaust and blocking your exhaust way.
Don S
Re: Engine Oil
What do you mean by lower part of the engine? The oil pan?
Does the engine temp gauge on the dash indicate an overheat or do you have an alarm going off?
What was you aiming at when you measured the overheat?
Does that mean that everything was OK prior to replacing the pump and thermostat? and which pump are you referring to? Raw water pump or the circulation pump?
What did you compare that to in order to determine an acceptable amount?
dingdongs
Re: Engine Oil
did you change the impellor in the drive as you cannot be getting flow through the engine.do not run again until you replace impellor as engine will not survive 4 long.have you run the engine ever without water muffs being connected to the outdrive.if the answer is yes then the impellor is toast.
misslynnie
Re: Engine Oil
Never ever started engine w/out muffs and drive impeller has not been changed.
dingdongs
Re: Engine Oil
would check impellor to confirm its all there and replace in any case.as a quick check you maybe able to undo hose clamp on hose that comes from drive to your thermostat housing.turn water to muffs on and see if you have a good flow.maybe long enough to put in a bucket.a 30 second run will not do the engine any harm.had you ever sucked mud up recently into your drive as you may have a blockage.
