I may have used incorrect wording in the title but I can explain it here.
1996 Wellcraft Excel Outboard
The trim button on the throttle and the engine are both unresponsive in moving the actual engine.
The fuses all read good. The gauges read good, The engine starts fine.
Just not sure where to start when it comes to diagnosing this problem. I have not tested the line for power yet but plan to do so. However the buttons being in two separate locations are most likely not on the same line.
Any advice or things I should try will be greatly appreciated and done.
Thanks Iboat members !
