engine lugs down at full throttle
lud2316
I have a 1989 force engine[model#1258A9D] 125HP <br />Motor starts and runs fine when going out,but once it is shut off after running a while it starts up ok but doesn't want to idle and shuts down when taking off or trying to load it,Lugs down.Had it checked out at the boat repair shop.Compression ok-ign system ok-dyno tested ok.They just ran it at the shop not in the water.HELP
roscoe
Re: engine lugs down at full throttle
Sounds like a classic case of fuel pump flooding.<br />Seems to happen alot, especially with 10-15 year old Force motors. Seems they didn't hold up to the new fuels on the market today.<br /><br />Basicly the seals, springs, and diaphram in the fuel pump get old and develope leaks. All is fine when you first run the cold engine.<br />When you turn it off for a while, the fuel leaks thru the pump, into the powerhead, creating a severely flooded condition ( possibly fouling the plug) in the lower cylinder when you turn the motor over.<br /><br />The good news is that the rebuild kit is less than $15 at any Mercury dealer, and you can do it yourself in about 30 minutes.<br />The kit comes with directions. <br /><br />This should probably be done anyway, on a motor of that age.<br /><br />I hope this solves the problem.
97trophy
I had this same issue. I rebuilt the carbs for 12 dollars per and rebuilt the fuel pump. The engine now runs like a champ.
12Footer
Welcome to iboats, lud2316.<br />Check for a dead cylinder or two, if the motor runs fine in nuetral, but stalls under load.
lud2316
have ordered carburator rebuid parts can tell more after installing them
fixin
I would do fuel pump too,cheep and easy.
