Engine losses RPMs after some time
Sergio Uribe
In my boat, there are two Mercruiser 4.3LH engines, with Bravo III outdrives.
When I first start the engines, and after letting the engines warm up, I then push the throttles to reach cruising speed, and let's say I stabilize the engines at 3600 RPM. The engines are showing normal temperatures, and oil pressure. After cruising for about 35 minutes, suddenly the right engine starts loosing RPMs, and if I leave the throttle where it was, the RPMs would go down and finally the engine will stop. But if I pull the throttle down to minimum, the engine would not stop, and continue running at such minimum RPMs. (I have to pull the other engine down, because the boat would not continue cruising with only one engine). If I then wait for about 5 to 10 minutes, then I could bring the two engines back to cruising speed, but the loss of RPMs of the right engine would come after a time shorter of the 35 minutes of the first failure. If all of the procedure is repeated, the third loss of RPMs comes after a shorter time, and so on.
If all of the above procedure is done but stabilizing the engines the first time at about 4200 RPMs (instead of 3600), the first loss of RPMs would come after cruising for about 25 minutes (instead of 35).
If all of the above procedure is done but stabilizing the engines the first time at about 3400 RPMs (instead of 3600), the first loss of RPMs would come after cruising for about 40 to 45 minutes (instead of 35).
The question is simple: what is wrong, and causing such strange operation ot the right engine?
FreeBeeTony
Re: Engine losses RPMs after some time
Do both engines run off the same fuel tank? If not it could be a clogged vent on the fuel tank of the problem engine.
Sergio Uribe
The answer is yes: both engines run off the same gasoline tank, but have separate pick up tubes.
Sergio
dubs283
sounds like a fuel delivery issue
time to inspect the fuel system from tank to engine, filters, lines, pump, etc...
is the engine efi or carb??
Ayuh,.... Ditto,.... No doubt a fuel delivery Issue,....
Sergio Uribe
Thanks for your reply, and have checked the fuel delivery system, but will do a further check. And the answer to your question is that the engine is carburated.
agallant80
I had the iginition coil go bad on me once, it did the same thing. I would try swapping the coils and if the other motor does it then you know what the problem is.
Augie56
Heat related...try swapping/replacing ignition coils.
agallant80
Yes when this happened to me as the coil warmed up the motor started acting funny. When I gave the motor 10min to cool off it was good again until it warmed up again.
Sergio Uribe
Thanks Don S for your reply, and will get prepared to perform this test of the fuel supply system next week, which is when I will be able to go again to where the boat is. After the test, I will get back to you with either good or bad news. Sergio
Sergio Uribe
Thanks for your suggestion of swaping the ignition coil, and that test was already in the program of tests to be performed. And what would you think about swaping also the carburators? Sergio
Sergio Uribe
Sounds familiar! We are definitely planning on swaping the ignition coils, as probably among the first things that will test. Thanks, and will comment again after the tests next week. Sergio
Sergio Uribe
Again thanks to the guys that have helped with their suggestions. This weekend, with the aid of a friend, we tested at the same time swapping the ignition coils, checking the vacuum in the fuel suction side, observed in a clear hose for air bubbles in the fuel supply, and had a couple of bulbs wired in parallel to check the electricity supply to the ignition coil, and to the fuel pump. All of the above was connected to the engine that was giving the problem of loosing RPMs at a certain point in time, and then more frequently. The only thing that was moved to the other engine was the ignition coil. And 45 minutes after starting the test at 4200 RPMs, the other engine lost RPMs, and right there the origin of the problem was completely clear: the ignition coil (and probably the connection with the cable that delivers electricity to the distributor).
So, problem solved, and again thanks for all the contributions. Sergio:joyous:
Sergio Uribe
And may God bless you all!. Sergio:joyous:
