engine loses power
Don Howard
I have a 90HP Mariner engine built in 1989. After running fine for 15 or 20 minutes the engine loses power although the throttle is all the way open. I have new fuel tanks and hoses and have checked that the vent on the fuel tank is open. Any Ideas?
Re: engine loses power
Ayuh,... Welcome Aboard,...
Sounds like it's goin' Lean...
Probably oughta rebuild the carbs...
wellsc1
Maybe consider the fuel pump too. I forget how high, but it's a high percentage of time that the fuel system is usually the culprit. Have you replaced the fuel filter in case is has a partial restriction?
Don Howard
I will change the fuel filter but why would the engine lose all its power and run at an idle after running fine for 15 or 20 minutes. Another thing I did not mention is this problem happens after I slow down (under a bridge) and then try to go fast again. If I let the engine sit for awhile and restart it work fine until the engine gets hot again?
SaabFAN
I had the exact problem with my outboard-engine 2 weeks ago, after cruising for ca. 10 to 15 minutes at 40% throttle while planing. After slowing down and accelerating again, the engine sputtered, then stopped and only started with the choke pulled.
Solved it by re-adjusting the idle twice.
Seems to me, like something had clogged the fuel-jet inside the idle-circuit of the carb that came loose because of the fuel-system cleaner i mixed into the fuel at that weekend.
Don Howard
problem solved. There was dirt in the carburator and the fuel jet was getting clogged. Cleaned the carburator.
Thanks for your help.
