1993 Four Winns 4.3L V6 OMC out drive. Arizona boating (1300 ft MSL, usually 100+ F temperatures)
Hello All, long time reader, first time poster, looking for an assist. I've been experiencing this problem for nearly a full year with the symptoms getting progressively worse. I'm including all the information I have, so this may be long.
Around a year ago I started experiencing an issue like clockwork. The boat would start off the trailer fine, idle fine, pick up on plane fine, pull tubers and skiiers fine. We'd take a break, anchor for an hour or so, and start up again. The boat would start right up, idle fine, even pull out of the hole on plane fine, then 5 or so seconds after up on plane, lose power, RPMs, and die. It would typically start right up and we could pull a skiier out of the hole full power and not experience another loss.
This season, the problem is getting worse, especially the last couple times out. The boat will die a 2nd or 3rd time in the same way after the first loss of power. Now the engine is not starting back up very easily, or will start, struggle, and die multiple times without ever getting into gear. Last time, I went thru the cycle of starting it, getting into gear, getting about 100 ft, struggle and die maybe 5 times before it finally seemed to resolve enough that it stopped dying and I was able to get back to the dock with full power, a 5 mile run straight back without issue.
I've noticed a few things, the electric fuel pump, which was the only thing I've ever replaced 3 years ago is screaming as if it has a bad bearing. It's also too hot to touch within 5 minutes of the boat running. I pulled it off the engine, and ran it with no load and it's pulling about 8 amps at 12 volts, seems high although I can't find a spec on what it should pull. I haven't done a fuel pressure test yet. The heat and sound is the same if I pull fuel from a short hose out of a gas can. I replaced the fuel filter, same results. (Doesn't seem related to blockage from the gas tank to the pump) Engine running temps right in the middle of the gauge.
I cannot reproduce the dying problem in by driveway with muffs. Starts, idles, revs up what seems to be perfect. I'm about out of ideas beyond buying another pump and seeing if it fixes my problem. Help me iboats forums, you're my only hope.
