engine locks up when running
daverush
I have an older 1967 johnson outboard motor. The motor starts up fine and run good for about 5-10 min full throttle and then slows to a stop. It happened once before when I ran it about 1 month ago, I waited for about 20 min to start it up and it ran great the rest of the day. On another day about 2 weeks later I ran it all day without any problems. The last time I ran it, it gave me problems again this time it left me stranded in the middle of the lake. It ran good for about 20 min then slowed to a stop the engine seemed excessively hot and I then noticed I could not use the pull cord to even turn the engine after an hour of floating around and letting the engine cool, I took a pair of pliers and wedeged it in the fly wheel to turn the piston over. The engine seems like it's locking up. What could it be? The oil mixture is good and new gas. could it be the the engine is not getting water thru it? water pump problems? any help would be much appreciated. thanks
Spidybot
Re: engine locks up when running
Agreed, indeed.<br /><br />Appearantly you are overheating the motor to a degree, where the pistons are expanding so much, they can't move in the cylinders.<br /><br />Normally this will cause the pistons and cylinder walls to seize.<br /><br />There is a small chance though, that it is only damaged - not completely ruined.<br /><br />You have to make sure the cooling water gets around in the water jacket - this is done by the impeller.<br /><br />If your motor does not have a tell-tale, you should at least be able to see water coming out with the exhaust.<br /><br />If the worst has happened you should do a complete calculation as a motor this old probably is not worht the $$ of fixing.<br /><br />A bargain on a newer will even get you the benefits of modern designs and better mpg.
