drewpster
- Oct 17, 2006
- 2,059
I finally got it done! I have been working towards this for a long time. Finally things came together. Here is how things went.
First I set the gantry to height. It is a scary 12 feet from the ground to the beam!
After removing the canopy, un-bolting everything and rigging the leveler and chain fall, I started to lift it out.
I made sure the gantry was level. It took the weight with ease and remained centered through the whole process. I eased it up out of the bilge and worked up and down the ladder moving the gantry and lifting the engine. Here things get a bit hairy. To clear the transom the engine had to be lifted all the way up. It cleared the transom deck by an inch or so eight feet off the ground.
I kept working aft until the engine cleared the boat far enough to lower it to a safer level.
A little more maneuvering and it is on the stand in the shop. By then I was sweating and its only about 50 degrees here today! Home build gantry did its job! Now what do I do?
