Hey, i have a 50hp evinrude motor, the engine is from 1972 but still in great condition, I recently started to work on it and the engine just wouldnt start, put fresh gas in primed it etc. I took off the cover and sprayed some carb cleaner in the carb and it started up for a second or two and then died, im guessing the carb cleaner is what ignited to start the engine, so i know its not seize or bad. I think took a cup of gas and poured it straight into the carb and engine started right up and stayed on for a good 10-15 seconds until it ran out of gas. So i came to a climax that the engine just isnt getting the gas. I followed the lines to each section of the motor and the gas flows to the filter fine, then to the first carb fine and im not sure if the second carb is causing this issue. I will take it apart because im guessing theres a clog in the line, but im just not sure how the engine operates. Im used to small engines with just one carb and intake line. If anyone can help me out and tell me what u think the problem is that would be great
