Engine ID
95Bayliner
What can you tell me about engine ID: 0E120544?
I'm trying to figure out if I can upgrade to a 16amp stator and find additional parts.
roscoe
Re: Engine ID
Serial number only tell us it is a 1995 model.
ASSUMING YOU ARE REFERRING TO THE 120HP IN YOUR SIGNATURE, the model numbers produced that year were:
H120412RD
H120412RR
H120412RX
H120422RD
H120422RX
If your motor has a rectifier, get the 9 amp.
If it has a regulator, get the 16 amp.
If you want aftermarket replacement parts, go here:
http://www.iboats.com/Force-Outboar...1402890--**********.320489170--view_id.271680
If you need to look up Mercury factory part numbers, go here:
http://www.crowleymarine.com/parts.cfm
95Bayliner
Re: Engine ID
Thanks guys!
I couldn't find the Model number so I called 920-929-5040 and provided the serial number. They said the serial number links to the H12012RD Model number. He said it was a 1995 Force 120 ELPT (Electric start, Long shaft with Power Trim). He also stated that it has the 16AMP with regulator.
