MikeDobbs
Thread starter- Joined
- May 8, 2015
- 206
This is a mercruiser 3.0lx engine
When we got to the water today the boat started up, idled, moved into and out of forward and reverse gear in the water all completely fine. When I went to move from idle to a 5mph no wake speed, the engine stalled out. Started right back up, and hesitated badly as I tried to bring the engine up through the 1500-1800 RPM range. After feathering the throttle I was able to get it "over the hump" without stalling, and once above approx 1800 RPM the engine ran perfectly fine. I was able to get up on plane, had plenty of power, and the engine responded well to both gentle and aggressive throttle movements. We went out and had a great day on the water. The boat ran fine at idle, and fine at higher RPMs, but continued to hesitate whenever moving through that 1500-1800 range.
I'm thinking something with the carb- maybe the idle/low speed jet circuit?
One other thing, possibly a coincidence: when getting gas I normally dose the tank with Startron enzyme treatment. The last time I filled up I did not because I had neglected to reorder when I previous bottle ran out. I didn't figure it would be an issue, since I was only adding gas to a tank that had treated fuel in it already (this was about a week ago). So, after the initial issue today, I went back to the dock the grab the new bottle, and gave the tank a dose of startron- hoping it would just kind of work itself out after running around for the day.
Any suggestions would be greatly appreciated. Thanks in advance!
