Engine Head Bolts-How much torque?
justin14
I have a 1986 OMC 3.0L 140hp engine in our boat in which i am replacing the head gasket, and i am wondering how much torque in ft-lbs i should apply to the 10 bolts which hold the head together.
sea wolf
Re: Engine Head Bolts-How much torque?
90-100. Hope you know the sequence.
Kessi
I keep the upper limit to 90-93. Don't forget to coat the bolts. I also add a little white lithium grease under the head of the bolt, a machinist told me that trick.
bruceb58
You do it in 3 steps:
35
65
95
And in the proper sequence as outllined in the service manual that you should probably get.
bruceb58
I will try to show the sequence:
REAR
9 10
5 6
1 2
4 3
8 7
Front
Does that work for you?
