engine floods when it gets hot.
odde
Any ideas on what would cause my engine to flood when it gets warm. Runs great when cold. After i turn it off ( when warm )and let it sit for about a half hour it stalls when i put it in gear. I pulled the plugs and they are wet and fouled.
crxess
Re: engine floods when it gets hot.
Carburetor float pin sticking or float set improperly.
odde
Thats what i am hearing. I took it apart and cleaned it, but it didnt fix it. should i replace the the needle and seat and set the floats?
19ftSigna
just curious, i was having the same problem with my 75 johnson 115. I rebuilt carbs, how exactly do you set the floats? what does that mean?
odde
i bought the repair guide and it gives the instructions. you need to find the correctsetting and adjust the float pin. i havent done it but the book makes it look easy. ( too easy so i know i will mess it up)
crxess
LOL - don't panic. It really is easy.
