engine feels like it was cavitating
lanejumper
i have a 85 Johnson javilin on a 17 ft bay liner Capri when i turn to right or left engine revs higher and i loose power boat has 24 inch transom the boat is a 90 the motor is a 77 i know it is not original equip if the boat is on the trailer i put the engine down it almost hits the ground so i dont know if it is still to high was told that the motor is a 20 inch shaft but i dont know if i should belive him i dont know how to tell for my self am afraid he was just trying to sell me his motor if it is the wrong highth would a jack plate fix my problem if so what about my sterring cables i am confused trying to learn boats are more confusing than cars
ksubigbuck
Re: engine feels like it was cavitating
It is doing that because your prop is coming out of the water when you turn. Lower the motor 1 or two holes and see if that helps.
Hunter
tashasdaddy
the anti cavatation plate should be even or just above the keel of the boat. making fast sharp turns will do it also.
lanejumper
i have to check to see where the anti cavitation plate sits on the boat what if it is higher than the keel what do i do then would a jack plate fix that
kenmyfam
How about a photo. Best bet to get a proper diagnosis.
