evinrudexp
- Apr 13, 2006
- 34
Hello Everyone! I Have Posted About This In The Past So Forgive Me If You Have Already Read About My Issue. I Have A 1988 Evinrude Xp Vro 150hp Motor That Will Run Great At Idle But As Soon As I Get On The Throttle It Will Start To Die Out Unless I Pull Back On The Throttle. Sometimes It Will Start To Die Out And Lose Power And Then Out Of Nowhere It Would Take Off. When It Would Start To Stall I Tried To Prime It But Nothing Would Happen. I Also Tried To Pump The Primer Bulb But No Difference.
I Have Done A Compression Test Which Reads 95psi On All Six. I Have Done The Spark Test And It Did Jump The 7/16 Gap With A Good Spark. I Have Just Rebuilt The Carbs.
Im Not Sure If It Matters But The Tach Doesnt Work. Im Not Sure If This Relates To My Current Problem Because The Tach Hasnt Worked For A While Even When The Motor Ran Great.
When The Motor Runs It Runs Really Good, But I Havent Heard That In Over A Year
What Else Should I Do?
Thanks For Reading
Thanks For Reading
