Manateeoncruise
Thread starter- Joined
- May 28, 2012
- 3
I do have the following problem with my Polaris Jetski Marine 700 LE:
It starts up after several tries, it accelerates to high RPM, but when you throttle back to idle the engine dies. Idle seems to be a little rough.
The carburator has been cleaned. I have not been able to measure the compression of the engine (no tester) but took the heads off and looked at the cylinders. Both look fine to me.
We checked both spark plugs when start difficulties occured - they are wet. Hence we do not suspect a fuel problem.
We cleaned the air filter.
Last option we can think of is the ignition.
Does anyone has experience with the ignition box or the above described problems? Any ideas?
Thanks for help!
Thanks for help!
