Engine cranks in up position but not in the down position
Richsandwich
Hey guys weird situation going on. I have a 1990 Johnson 60 that worked perfect last year before I winterized it and covered the boat. Now this year when I put the engine down and turn the key I get no cranking or power what so ever. When I pull the engine to the up position and turn the key the engine will crank and gets power. I'm not a boat mechanic so not sure where to start looking. Let's just say good thing for the trolling motor :)
jakedaawg
Get rid of the wing nuts and use a nut and a wrench to hook up your battery. If that fails you have a bad ground, a bad Batt +, or a bad yellow/red wire.
Crosbyman
likely an open wire that makes internal contact as it moves up ...check all wires ​ that flex for continuity
​I had a similar issue years ago on a 50 HP merc side plug harness to the engine......it would die as I change direction
Richsandwich
Thanks for the quick replies. When the weather cooperates I'll get outside and take a look at those suggestions and get back to you guys.
