Engine Compartment storage???
Rovey14
I know this may seem like a funny question to most but I'm going to ask anyway.
Has anyone ever built in extra storage to their engine compartment?
I have a Larson 180 SEI and there is a tone of unused space in the engine compartment. Located right behind the rear seat.
I would like to securely modifiy some storage crates into the compartment for extra storage. I was wondering if someone has done this before and if there is a site selling supplies to do so?
45Auto
Re: Engine Compartment storage???
My 22' Crownline has lots of storage on each side of the engine under the sundeck. Offhand, it has the following stuff under there:
Port side (hydraulic pump side): waterproof tool box, tupperware oil container (engine oil, outdrive oil, hydraulic oil, steering fluid, WD40, 3in1), package of 4 life preservers, bunch of pool noodles.
Starboard side (dual battery side): Porta potti, 20" fan, 120v inverter, kid's sand toys, bunch of air mattresses and blow-up toys.
Mine has insulating panels on each side of the engine. The stuff is stored between the insulating panels and the hull.
If you're going to build your own storage I would do the insulating panels beside the engine to keep things from getting too hot.
Rovey14
That is a very good point. I will use the insulation. Thanks so much.
tashasdaddy
remember the area has to have ventilation. you can seal it off completely, or possible BOOM.
