1999 Searay 180BR
Thread starter- Joined
- May 23, 2006
- 43
I have a 1999 SeaRay 180 Bowrider with a 3.0L Mercruiser. I didn't get to run it last summer so it has been sitting awhile. The engine would crank and idle but would not take the gas when the throttle was advanced.I assumed bad gas or gummy carb so I siphoned the tank dry and filled with fresh gas (93 octane),removed carb, disassembled and soaked in ChemTool carb cleaner for 2 days, installed new complete carb kit, inspected fuel pump filter( looks good ), reassembled everything. It cranks and idles fine. It will even taxi fine, but when the throttle is advanced it bogs. The engine never dies it just won't open up. In neutral with high idle it will rev off the scale, but in gear WOT = about 2000rpm maybe a little more...any ideas?
