I have a 98, 50 hp Johnson. At full throttle my engine will no go. It seems to do fine at idle speeds. I replaced the fuel filter but it is still doing it. Any suggestion?
suspect tank venting and/or fuel pump.<br />You can check the venting by removing the gas cap enough to allow air to enter the tank. If it picks-up, this is the problem.
