engine block for johnson 175 horse
dilbert
where can i get a engine block for a johnson 175 horse faststrik 91 year model
Dhadley
Re: engine block for johnson 175 horse
Are you looking for a block only (empty block - no crank, rods pistons etc.)? Or a powerhead?
dilbert
well im new at this i not sure what a power head is but maybe a full block with crank pistons and all or just a block maybe mine is cracked
Dhadley
It can probably be welded unless its broke across the mating surfaces. If its just the front case or even in a non-mating area of the block its no big deal. If it trashed the rod bearings you probably need a crank also.
Walker
Where are you located dilbert??
