- Mar 8, 2009
- 44,319
OK thanks
If fuel pressure is the problem then what could be causing it?
Depends on what the pressure is. If you going down below 2 psi, maybe a restriction, maybe a weak pump. If your not getting 3 at idle and/or 5 at cruise maybe weak pump
If pressure is good, then could be the carb is not passing enough fuel, for one reason or another.
Give us the numbers and we can figure it out.
