I have a 270 hp crusader that causes an alarm to go off around 3200 rpms. I think the alarm is only for the temp and pressure but both are reading fine on the gauges.When i back down on the rpms the alarm turns off then i can bring it back up and it will run fine for a while and the whole cycle starts over. also im not sure of recomended rpm range for this engine.one more thing i found strange is that the engines have crusader tags but the intake and the exhaust manifolds both say mercruiser should this matter?
