engin tear down
tkq23111
I have a 1968 50hp thunderbolt ser=2454257.Iam doing a rebuild.I have disasembeld the engin and cleaned it all up,the exhaust side was bad full of crud,cylender walls are not bad,where the head gasket goes there are some chips.I was wondering if i shuld put some gasket seal just where the chips are and then the gasket .If so what sealent should i use.I know your not supposed to use sealent on the head but what if i only put where the chips are.The reson i started doing a rebuild is because cylender #4 ,psi only reads 40 psi ,the other three read 119.when i took it apart the rings where melted into the piston groves on one side.I cracked the Lower End Cap when taking apart ill include a picture ,could i reuse this part or get another and where can i get a used one .I have got a new piston,a complete seal kit and have cleand the piston chamber side of motor real good,i cleaned it but didnt hone it.the other side with the pistons on it i left everything alone .ive only blowen clean with air.the rings look good and pistons look good but a litle carbon on top of pistons.this is my first time doing this and the only experiance i got is reading poasts.ill includ pics and could anyone give me some pointers.ty all.
merc850
Re: engin tear down
A Mercury dealer sells PERFECT SEAL to seal the crankcase and it is good to put on bolts to stop them corroding. You will need gaskets for the exhaust/water jacket as well, as for the lower cap try your dealer,ebay,iboats etc.
tkq23111
Re: engin tear down
so i would use the pefect seal insted of a head gasket is that what your saying because i cant find a headgasket anywhere.if so is there a certain brand of pefect seal i need.ty all.please help im read to put back to gether.also i have a couple dings where it goes together will the erfect seal take care of it.
carholme
Re: engin tear down
tkq;
Do you have a parts list for your engine and if so, what p/n are you using to search for a head gasket?
Gerry
tkq23111
Re: engin tear down
Im talking about part numbur 1 in diagram.the CYLINDER BLOCK where it goes together.i dont know if a gasket is needed there .ty
carholme
Re: engin tear down
Well it is confusing as you keep talking about a head gasket but the only gasket on that side of the engine is item 47 which is the gasket for the block cover.
If you are talking about the joint between the crankcase and the block, there is no gasket there and definitely not a head gasket.
Gerry
tkq23111
Re: engin tear down
Im back at it again and looking to find a pdf manual.I have allready bought one a couple days ago but its the wrong one .can anyone tell me where i can get one .I have seen this sight but cant find it there.http://forums.iboats.com/showthread.php?t=309079
the motor is a 1968 50hp thunderbolt ser=2454257.Included are more pics.Im ready to put back together and need torque readings and
tkq23111
Re: engin tear down
TIGHTENING TORQUES (All Models)
(All Values In Inch-Pounds Unless Noted)
Connecting Rod 180
Crankcase screws 150
Cylinder Cover, bolt & nut 100
Exhaust Cover 150
Flywheel Nut . 65 Ft.-Lbs.
Reed Screws 35-40
Spark Plugs 240
Transfer Port Covers 45-60
on this page are the numbers the page or the torque per square inch.ty
and carholme ty thats good info. http://web.ebscohost.com/serrc/pdf?...8-a64b-54a4d1d3cd31@sessionmgr14&vid=4&hid=13
carholme
Re: engin tear down
tqk;
The link you provided is not working but if these are the torques you are referring to:
Connecting Rod 180
Exhaust Cover 150
Reed Screws 35-40
Spark Plugs 240
The numbers beside the component is the torque range in in/lbs., except for the Flywheel, which you will see is in ft/lbs.
Gerry
tkq23111
Re: engin tear down
more pics of 1968 50 hp thunderboalt.IMAG0414.jpgIMAG0415.jpgIMAG0416.jpgIMAG0417.jpgIMAG0418.jpg
still looking where i can but pdf manual
tkq23111
Re: engin tear down
I am having problems findind a inch pound torque wrench. I went to sears,advanst auto ,lowes and home depo,and nothing.I converted it into pounds so i can use a foot pound torque wrenck.Can you tell me if this looks right.also i had to buy a crows foot wrench because torque wrench was to big.ty
1.connection rod . 180 inch pounds =15 ft pounds
2.crankcase screws 150 inch pounds =12.5 ft pounds
3.cylender cover,bolt and nut 100 inch pounds =8.33 ft pounds
4.exhaust cover 150 inch pounds =12.5 ft pounds
5.flywheel nut =65 ft pounds
6.reed screw 35-40 inch pounds =3.3 ft pounds
7.spark plug 240 inch pounds =20 ft pounds
8.transferport cover 45-60 inch ounds =5 ft pounds
mr 88
Re: engin tear down
Yes your math is correct..in lb to ft lb multiply by .0833 ft lb to in lb multiply by 12
carholme
Re: engin tear down
Though your math is correct, there is no way I would use a ft/lb Q wrench for the lower values unless it is a very high quality wrench and has been recently calibrated. Then you have the added problem of using the crowsfoot, which depending on the angle you are using it at can alter the value of the read torque.
For reference:
http://www.finishing.com/118/94_crows_foot_torque.shtml
Gerry
tkq23111
oldman570
Re: engin tear down
For parts try going to Old Mercury.com website through your browser. or CDI website for stator and recitifer. Check out sticky for Outboard Salvage Yards also.
Oldman570
tkq23111
Re: engin tear down
stuck on the control box,.pics included.I half way referbished the wiring,but did fixed the saftey nuterul swith that wast working also cleaneView attachment 133182d the hole control box up.The throtle cable piece that holds the cable into place was worn and not working and is my main reason for posting this.so i filled it in with rubber cement because thats all i had in hand and it didnt work so i boaght a stick of J-B STICK epoxy.what is your opinion
