Hi,
I'm currently cutting out all the pieces of plywood that will be used in my re-flooring project.
I plan to coat all the surfaces with thinned ( to rubbing alcohol consistancy) poly resin. This, will then be catalyzed with a reduced amount of MEKP to allow for a longer kick time, hopefully allowing the resin to penetrate the wood fibre befor curing.
My question is ; when you fellows say "encapsulate", do you mean to cover both top and bottom of the plywood floor with mat?
Or, do you mean to apply a coat of the resin mixture to all surfaces followed by the mat on top?
Thanks for any help.
