Re: Encapsulated Bilge Keel moulded to the hull stress cracks. Keel Strengthen projec
hi martin.....and again......ask away !
sorry for the grp confusion....there are so many possibilities that is just wanted to make sure.
the best thing is to get pics up.....as each job can be different.
what is your supply of glass like?....can you get speciality glass ..like a tri ax?...
ok......first off.....to do any good glass job......the sub straight (your hull) must be ground off till you are at glass only.....no epoxy putty.....
if you do find that you need filling as in a scar.....use the structural peanut butter recipe in the thread i gave you.....milled fibres and 1/4 inch short strand fibres.
this will give you a very hard structural putty.
if there is any epoxy on the boat.....and you wish to continue with epoxy, you can......but only use epoxy fillers....then your fibreglassing must be done with epoxy....epoxy and poly do not like each other...so once you start with a product.....stick with it and do the whole job with it.....
I dont like using epoxy because of the long cure times...but it is an excellent choice for your repair.
the two different products use different approaches.
I will start with a lay up schedule for poly..... this is for the outside only at this time......
grind the hull till all contaminants are off the glass.....any paint, old resin. filler.....anything....you want the new lay up to bond to the old glass.....
if you have a crack 1/4 inch wide by 15 inches long...... you will grind 6 inches wide by 20 inches long....
if you want to re enforce the keel at the pressure point....and make the area stronger by using glass.....then grind the whole area....a couple of feet wide by (the length of the keel)
by a few feet deep and up the hull shy of the water line.
after you grind the area......wash the area with acetone. good and clean..... then use a rag dipped in styrene and wipe the area.
wet out the area liberally by applying resin and brushing it in, in several different directions.....the resin will try not to stick at first, so make sure you brush or roll it vigorously in different directions. you want the resin to contact the hull completely with no possible areas of non contact. (the first wet out is important)
apply your first layer of chopped strand matt, a (.75 or one oz) to the area.....this will be a smaller piece than the area.....if you are repairing a crack.....this peice is just the size of the crack.....1 inch by 15 ins wide. if the keel is being done.....just the area of stress or maximum pressure. roll that in with your resin roller till the glass is fully saturated.....but with no resin pooling.......the less resin the better....your next layer will be a 1708 bi axe (tri axe if you can get it) the same size of the csm.
you want to do this several times.....with each layer being larger that the last........there must be csm between each layer of glass cloth. the following layer of cloth the same size of the csm. if you are doing a re inforcement. these areas are much larger.
use your resin roller to make sure there is no air between the layers. you can do as many as three layers of the heavy cloth over each other, but if you do more...the resin will get to hat during cure and become brittle. so after 3 csm/1708 layers. stop till the glass semi cures and the heat has gone out of the cure before you start again.
if you are doing a full keel pressure point area.....the final layer of 1708 will be much larger than the one you first layed......and fully cover the entire surface that you ground off.
it will also need to be finished.......so on top of the 1708 add another layer of csm, and then a 6 oz woven finishing cloth.
this will give you a very smooth final layer to add your filler to or sand for gellcoat.
3-5 sandwich layers will be fine for the re enforcement area. a good long final layer running from the mid point of the keel to below the water line, will be great.
if you choose to use epoxy.......just leave the csm out.....you dont need it. and it will actually make things harder for you.
if you are able to get to the inside as well......a similar 3 layer sandwich of matt.cloth will work fantastic......and all your holes will be gone.
