Elgin 2hp recoil starter
freddyray21
One of the things this motor needed when I bought it was a new starter rope. I installed the rope and the recoil seems to work fine until I mount it to the motor. It will engage the motor but won't rewind until I take it back off. One of the things I did notice when I pulled it off to put the new rope on was it had two ball bearings that were sitting in the cup the paws sit in. I don't know if they are supposed to be in there or where they would go if they did.
steelespike
Re: Elgin 2hp recoil starter
Those are the clutch balls.There are supposed to be 3 and they work with the
clutch,the device with the three notches in it.
freddyray21
do they go in the notches? What I have is a piece that bolts to the top of the flywheel that for lack of a better description is triangle shaped. So I need a third ball bearing, but I guess they go in the points of the triangle?
F_R
They are designed to roll toward the center at rest, (so the recoil engages them) and fly outward from centrifugal force when running (to disenge them from the recoil.
