Electronics issue during engine run
813jimbo
Just wondering if anyone has had this issue before?
I have a 2004 Mercury 250 2 stroke.
3 months ago I replaced the batteries with no issues.
Last month I had the starter and key switch replaced from a service dealer, 4 days and $1300.00 later I have issues.
With the batts on all my electronics/running lights/stereo/vhf works fine.
With the key switch in the on position (engine not running) all guages and electronics/lights work.
With the engine running none of my electronics/lights work, when I turn on any of the switches for the electronics/lights etc. the fuel guage will jump to the left showing empty, when I turn the electronics switch (any switch) off the fuel guage returns to normal range.
When I shut the engine off all guages electronics/lights switches work again.
The issue only seems to be when the engine is running. Could the starter have been wired wrong? Or does this sound like a grounding issue?
My GPS/Depth Finder stopped powering up all together, It was on when I started the engine then shut off, I fear this problem might of blown the system.
All fuses and connections have been checked everything seems good.
Don S
Re: Electronics issue during engine run
Why don't you take it back to them and tell them what the problem is and give them a chance to make it right?
The dude that replaced the ignitiion switch was not an electrical genius. Some of these folks need a different occupation. $1300 to replace an ignition switch? You should have called the cops. Robbery is illegal in most states. I'd replace it "incorrectly" for half that amount.
813jimbo
Thanks all, I took it back to the shop this morning, they will check it out and call me by friday, I was just trying to get an idea of where the problem might be so Im not an easy target. 25 years of owning a boat and I have yet to hear a service center admit to a mistake. I will post their findings when I get the bad news.
Proving that they screwed up is really quite simple. You took a boat into their shop for what is a very simple switch replacement which involves electrics on your boat. You get it back and have all sorts of "electrical gremlins". They screwed it up and charged you dearly for that service (or lack of it).
