Electrical wiring Glastron 1977
DENCHES
I am about to rewire my boat,engine,gauges, 1977 Glastron 140 HP inboard. Some one spliced all kinds of different color wire, over time, to a lot of the runs. When I bought my new gauges the wiring harness plug did not fit into the old one and the wire color was different to each gauge. So I'm considering removing all the plug ins and wire direct (color coded correctly). I see a common ground is provided using a plug in, thus I would have to take all grounds to my fuse box ground. Are their any other reasons to keep the plug ins???????
LippCJ7
Re: Electrical wiring Glastron 1977
I am sure this will get moved to the electrical section but I will answer your question my way,
Theres no reason you can't remove the plugs, but make sure you insulate your connections properly to prevent corrosion, I use heatshrink with heat activated glue to seal the butt connections (wire splices) and I highly advise you do the same. Also I would not take all of my grounds to a fuse block connection, I have yet to find a fuse block with a big enough ground buss for my satisfaction. Remember that grounds should have wire sizes equal to power and when you have 15 12 gauge grounds to a single buss then one 8 gauge ground to the battery your 8 gauge is way to small. Too many times people chase a power supply issue when the problem is actually a return issue. Not sure this is a problem in your situation but its food for thought.
Silvertip
Honorary Supreme Mariner
Boat instrument clusters do not need, nor do they have 12 gauge grounds, power, or sense lines. 16 gauge is perfectly adequate. If the fuse panel ground buss to battery negative is 10 gauge or larger that will be perfectly adequate. Instruments and the internal lighting don't draw much power at all. The engine harness is grounded through the engine block and the large negative battery cable so that harness ground is not an issue either.
Don S
One problem you will have with that age boat, is the wiring color codes were different back then than they are now with the BIA color coding method. If you plan on rewiring, decide if you are going to use the old color code method, or the new. If you mix them you will never know what you have.
Here is a cross reference chart from ABYC.
attachment.php
attachment.php
LippCJ7
Sorry I should have clarified that I was using 12 gauge wire only as an example.
DENCHES
Well, I can't thank you all enough for the reply's sent to me. I have an extra 6 feet of run, the original wire, wound up in the rear of the boat. I guess just extra length when installed new that's plenty to get me forward or backwards to connect. Don't laugh to hard but I'll have to do this one connection at a time, I'm new to this electrical stuff. But I have all winter, live in Wisconsin.
Thanks again !!!!!!
DENNIS
Silvertip
If you look at the stickies at the top of the electrical forum you will find one titled "Generic Boat Wiring Diagram". It will cover the vast majority of recreational boats.
