Re: electrical probs
The rectifier (actually a rectifier/regulator combination) is part of the charging system. As the flywheel spins, magnets in it spin past coils that generates an AC current. The rectifier converts that AC current to DC. The regulator maintains the output of the charging system to a safe level to prevent overcharging of the battery. The tach gets is signal from the rectifier. One of the indicators of a charging system problem is when the tach quits working. Thats why I told you to measure the voltage at the battery with the engine running. If its more than 12.6 volts at 1500 - 2000 RPM the charging system is working. If its 12.6 volts or less the charing system is not working. Since other gauges are not working, I don't think its a rectifier/regulator problem. It think you have some loose wires on your gauges or a bad ground. If you don't understand basic wiring, you'll need outside help to fix this.
