electrical problems
grandpa.buddy
I have two questions.<br /><br />#1 - I bought a '71, 50 hp Evinrude with electric shift, cables and controls from ebay and the ignition switch was missing the front part where the key was suppose to go. I bought a new switch with a key but the backs of the switches are different and I don't know which wires go where. Here's a picture.
electric.htm
My 5 wire colors are white, tan, black/yellow, black, red/purple. The new switch is a Bombardier Evinrude/Johnson 0386947<br /><br />#2 - I also need to know which wires attach were on the shifter control. I have six wires but only five connections. See the above picture. My six wire colors are purple/white, gray, purple, purple/green, green, blue. The blue switch is forward with a 2 and 1 under it. The white switch is neutral with a R and + under it. The red switch is reverse with an N under it. Also, what is the extra for? <br /><br />Just incase my picture link doesn't work, the picture is at http://www.gummashouse.com/electric.htm <br /><br />grandpa.buddy
rodbolt
Re: electrical problems
Hello<br /> wow its been a bit since I worked on one of the old push button motors. white is the old color for start and goes to the s terminal. tan is for an overheat horn or some of the old boxes had a light. black/yellow is kill and goes to one of the M terminals. black is a ground and goes to the other M terminal.<br />red/purple is fused 12positive and goes to the b terminal. on the shift side of it the one purple wire goes to the choke switch. the purple white goes to the othjer side of the choke switch and back to the engine. the gray is for a tachometer.the purple green is shift positive and goes to the center terminal marked +. the green goes to the terminal marked N. the blue goes to the terminal marked R.I hope this helps <br /> good luck and keep posting
rodbolt
hello again<br /> I keep looking at 2 different harnes diagrams. one says purple white is 12v positive from the solinoid and the other says different. dont wire it yet. I hate conflicting manuals<br /> I have a 71 50 hp out back. i will go look.<br /> :) :)
Droll
Hope this may help some .<br />
<br />white = Starter solenoid = S on "new switch" <br />tan = hot horn ?<br />black/yellow = Powerpack point 5 = M "new switch" ???<br />black = ground = M "new switch" ???<br />red/purple = From fuse/bat = B "new switch" ???<br />You schuld also have 3 purple wires to A "new switch"<br /><br />Gear switch<br />2 = Dk. green<br />R = Dk. Blue<br />+ = Purple<br /><br />Some from wiring diagram and some from my 50hp (1971 )<br />Correct me if I am wrong :) <br />If you want diagram "droll@online.no"
rodbolt
hello<br /> wow what an ordeal. I hate visiting the grave yard. reminds me how much I have forgotten. the purple white wires go to the choke and the purple red wires go to the bat terminal for fused 12 power. good luck and keep posting and if anybody has clymer manualb734 covering 1.5 to 125 hp motors from 1956-1972 you may wish to double chek the wire color codes at the bottom of the pages. I think they got two of them transposed. the manual is wrong.
