Electrical Problems
Smerritt244
I own a 2003 Crestliner 1600 SC Angler. When I first put it into the water, I noticed that the tilt/trim gauge does not work. I inherited the boat from my late father, and last year, it worked fine. I have gone through the fuse block and checked the wiring. So far, I could not find anything. My question would be, what is the best way to test the gauge its self in order to determine if the gauge is bad or not? I also still need to trace the wires back to the rear of the boat to check that end as well. Any suggestions would be welcome. I am trying to get this boat back into good order.
merit131
Re: Electrical Problems
I don't know and you have not got a reply. Go online, ask how to test a gauge, I'm sure you'll get an answer.
Ayuh,.... We've gotta know what the motor is, to determine what it's got for Trim, 'n tilt...
Smerritt244
Sorry, its a 2003 Mercury 2 stroke 3 cyl. Serial Number 0T826032
Silvertip
Honorary Supreme Mariner
Grin -- that narrows it down to 40, 50, 60, 75, or 90 HP across two different engine series and two (or three) different lower units depending on how specific we need to be. Should have been a dentist since extracting information is sometimes like extracting teeth.
