electrical problem
djrob
hi there guys i have a evinrude 1970 115hp 2 cycle<br />i seem to have a electrical problem. i had power to the solinoid at one time now i have no power.<br />when checked all battery connections wiggled all the wires but still no power. i had the motor running at one time today and now i cant get any power. the shifter indicater light doesnt luminate<br />which lets me know i have power. at one time i had to tap on solinoid to engage the starter. at one time. but then it seemed to operate with the key. when the solinoid didnt engage the starter i used my jump starter and with the key on the unit fired up. when i hooked the cables direct to the jump starter still didnt have any poewer.<br />any help would be apprreciated. :( djrob38@attbi.com :confused:
Joe Reeves
Re: electrical problem
DJ.... At the battery connection portion of the starter solenoid, you'll see other smaller wires connected to that same post. Trace the smaller wires backwards to a plug together type fuse holder. That is the main fuse link that supplies power to the ignition switch. I suspect you blew that fuse.
djrob
joe i have tested that fuse and it is good. can the fuse holder be replaced with a standard fuse holder just to be sure it is making contact.
sparkroost
how about your neutral safety switch in the control box? there might even be one on the engine, near the throttle, starboard side.
djrob
checked everything. i think the power pack went. need a power pack for a 1970 evinrude 115hp.
