Electrical nightmare
Wrongway1516
I have a 1979 Galaxy with a Mercury 120. Does anyone know where to find a reliable wiring diagram? I've looked in the Mercury book, but can't figure out which one I have because the wires on the boat are different colors than the diagram.
Re: Electrical nightmare
you have 2 sets of wiring on a boat. the first is the motor wiring which will be in the mercury manual for the motor and should be the same colors this will be a multi-core cable from the motor to the controller. the second is boat wiring which will be for pumps, fuse panel etc this will be by the boat manufacture. if you look at the sticky at the top of the electrical forum it will give you alot of good info on the 2 sets of wiring and surgestions on how the boat should be wired.
