Re: Electrical Help!! 2002 Stingray 220lx
get yourself a volt/ohm meter and start testing for battery voltage and griund beginning at battery and working your way out from there to where you don't have power. check all cables for tightness and corrosion. wiggle and pull every battery power wire connection. check the ground connection to the engine and ground buss to make sure there is a return path back to the battery. there is a very good tutorial on the forum here for download that explains power as related to boats.
