electrical disaster!!! please help.
BMerton
Hi my name is Brandon I was recently given a '96 Monark pro 160 bass boat with a 40HP force motor. This is my first boat and dont know a whole lot, Im kinda learning as I go. I finally got the motor running and the steering fixed and now none of the switches are working.(nav lights, anchor light, bilge, ect.) any ideas? I replaced all of the fuses burnt out or not...
BMerton
Re: electrical disaster!!! please help.
Some history on the boat. The guy that gave it to me had the motor redone a couple of years ago and never had time to take it out more than 2 or 3 times and it had been sitting outside his house for 2 years+/-. I got it home and hooked it up to my buddies gas tank because I knew the gas tank in the boat had gas in it from at least 2 years ago. That is something else I have to do. The only problem with the motor was a critter got inside the cowling somehow and chewed through one of the wires. I connected the two ends and it started right up. The next thing was the steering was locked up, or so I thought. I disconnected the control arm from the motor that way the hydrolic arm was free and I worked it loose but it was still a little stiff so I greased it and now it is just fine. Now the electrical part of everything The boat runs and steers fine. All I need to do it get all the lights, the bilge and the livewell pumps working. I am completely lost when it comes to the wiring and I am trying to get myself through school and move out on my own. Therefore I don't have the money to take it to a marina to have them figure it out because they will charge me $1000+ for a job i could have done myself with the right supplies and instruction. I was really hoping yall could help me out or at least point me in the right direction.
Thanks,
Brandon
Silvertip
Honorary Supreme Mariner
Look in the area of the battery. You should find the two large battery cables that go to the engine. Those you have connected properly since the engine starts. There should be two smaller wires (about #8 or #10 gauge) in that area. Those two wires are what feed the accessories. There should also be a fuse or circuit breaker in the red wire about six inches from where it connects to the battery. If the boat has any gauges, then those are powered from the engine harness which is the cable that runs from the engine up to the throttle/shift control box.
Check the stickies at the top of this forum (not this page) for "Generic Boat Wiring Diagram". All connections need to be clean and tight.
j_martin
When a boat is "stored" in the rain, the same fate is meted to the switches as happened to the steering. They get cruddy inside and quit working.
You'll have to trace things out to find the bad parts. You have already received some direction on that.
BMerton
I checked the fuses and they are not blown, just a little oxidation on the tab inside the glass. Is that a problem? how do I check the switches on the panel? I have a multimeter, I just don't know what to put where as far as the switches are concerned.
Silvertip
Here is a diagram of a single electrical circuit. While this diagram is for a light, it doesn't matter what the switch controls -- just pretend the light is any other accessory. Then follow the current. Start at the battery POS post. Place the POS meter probe on the POS wire and leave the NEG probe on the NEG post or ground. Move along the circuit. When you lose power you found the problem.
Another way to look at things!
kahuna123
Merton if you want to bring it over I will help you. I was a marine electrician and owned my own business in Tarpon Springs for a few years until I figured out I needed to make a living. I am probably 2-3 hours away. You can PM me.
BMerton
Thank you guys I started at the battery and worked my way down on the wires for the accessories and I lost power after the waterproof fuse box on the POS wire. I got a new one while I was out today to replace the old one. The old one had two fuses and West marine didn't have any double fuse only single ones hopefully that wont be a problem the guy there assured me that it wouldn't be. So her is hoping that was the only problem but if not then at least its one problem fixed.
