pursuit2460
- Aug 24, 2004
- 193
I just found that my flywheel magnets where lose the stator has the epoxy melted off and the triger base resistance is off according to the test that i performed from the manual. My question is if I replace the ststor and trigger base, if the power pack and rectifier are also bad will they damage the new stator and trigger base. Should I just go ahead and replace everything at once. Thanks.
