I'm looking into replacing the instrument panel circuit breakers. Originally the boat came equipped with E-T-A series 1658 thermal overcurrent breakers. I'd like to replace them as 2 have snapped the mounting heads off and one breaker is unservicable. At $5-8 each i'm just going to replace them all. Heres what the boat had originally for each rocker switch:
ACC-10 Amp (running 2- LED swim platform lights and 1- LED engine doghouse courtesy light)
Horn-10 Amp
Blower-10 Amp
Bilge-5 Amp
Nav Lgts-?? Amp (running 1- LED bow nav and 1- LED white stern nav)
Ignition Switch-?? Amp Off-On-Start, on position electrifies the guages
Should I keep the same amperage values as original? Boat had incandescant bulbs all around, I replaced and went all LED
Secondly,The sticker on the nav light breaker is missing so I dont know what it has originally what would be recommended for my setup?
Lastly, The sticker on the ignition breaker is also missing, what would be recommended? Did some reading and 20 Amp seems usual, does this sound right?
Thanks,
Mark
Horn-10 Amp
Blower-10 Amp
Bilge-5 Amp
Thanks,
Mark
