Electric
Igorshor
Hello all! I have 2006 Bay Stealth VIP.
All of a sudden my dashboard went completely dead.Starting battery OK.Trolling batteries are fine.Checked all fuses- nothing. Engine starts.No problem. Battery charging.
Sprig
Check for loose, broken or detached wire in the dash. Check that the connections are tight. Check any inline fuses not just the fuses in the fuse box. Check all the grounds. I find 50% plus of the time it’s a ground problem. Use a multimeter to determine where you have or don’t have current.
