Electric start switch mounting?
Mckeem
This may be a dumb question, but do you wire it up to the dash? I'm talking the key and start switch...from a 58 Johnson super seahorse 35hp...
gm280
:welcome: aboard Mckeem. Nice to have you join us here on iboats...
If you are talking about mounting a norm key ignition switch for your engine, then yes most folks mount them either on the dash or around the control unit. Not sure how your engine is setup. Some have a starter button on the engine cowling. But you will need the wiring harness to reach from the engine to the key switch wherever you mount if...
Chris1956
Honorary Supreme Mariner
Those older controls for a motor like his do not have any electrics. Pick a spot on the dashboard for the ign keyswitch.
F_R
AND a choke switch. Unless you use a key switch with push-to-choke feature.
Chris1956
V-R, Didn't those motors have the auto choke, vs the elec choke? My '61 was auto choke...
Mckeem
Thanks guys, just as i figured, I mounted it in the dash right behind the steering wheel perfectly. Just had to replace the ignition switch which was easy.
